Anonymous Posted on Oct 14, 2011
How to reset counter on canon dr 7580 - Canon DR-7580
Brian Martin
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Jan 18, 2015
Brian Martin
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
27348
Points
74
What counter do you want to reset?
The only counters you can reset are the "current rollers" counter and the session page counter shown on the LCD window in green.
To reset the green LCD counter to "0" just turn the scanner off, then back on.
To reset the "current rollers", go to "Control Panel" "Devices and Printers" or "Scanners and Cameras" (depending on OS) and then open the DR-7580 Properties>Counter tab>Reset button.
After 250,000 scans, you should get a warning to change the current consumable rollers.
If you are looking for a way to "roll back" the total scan count...well that would be DISHONEST...and I hope your scanner catches on fire :)
Mohan Sriraman
Level 2:
  • Expert 490 Answers
  • Posted on Jan 04, 2015
Mohan Sriraman
Expert
Level 2:
Answers
490
Questions
0
Helped
246991
Points
823
You need to run Qumatool to reset the counter
S. Mohan
5 Related Answers
mohanchennai
Mohan Sriraman
  • 490 Answers
  • Posted on May 21, 2009
SOURCE: Faded images canon Dr 7580
Clean the glass thoroughly. Try Automatic settings and try various contrast levels in mamual mode.
S. Mohan
Anonymous
  • 3 Answers
  • Posted on Jun 09, 2009
SOURCE: CANON DR 7580 SCANNER : SCANNED IMAGE HAS A LIGHT
Assuming the document going through the scanner looks normal, there are a few things to check. If you open Capture Perfect, you can adjust the contrast and brightness as well as the thresholds. Sometimes different toners react differently to the scanner...paper is a big thing too. Multi-part forms can be tricky to get the settings adjusted so you pick up enough of the text but not that on the other side. If it's still messing up, you can try and get it serviced. Ikon is nationwide and can help out.
mohanchennai
Mohan Sriraman
  • 490 Answers
  • Posted on Jul 20, 2009
SOURCE: In need of a service / parts manual for Canon DR
You can get spares from http://www.scannerparts.biz/servlet/StoreFront
Service Manauals are little difficult to get, need to search the web patiently. Be sure of the site, there are quite a false sites that rob you of your credit card details. S. Mohan
mohanchennai
Mohan Sriraman
  • 490 Answers
  • Posted on Mar 05, 2010
SOURCE: Canon DR-7580 misfeeds intermittantly cutting off
Select 'auto detection of page size instead of a fixed size.
S. Mohan, India
Testimonial: "We did that and still have the same problem. I am wondering if it could be the rollers. Thanks."
mohanchennai
Mohan Sriraman
  • 490 Answers
  • Posted on Sep 07, 2010
SOURCE: I have a canon dr-7580
Use Qumatool to check if all the sensors are working okay. Normally sensors dont fail, there must be a small piece of paper (like the 'dot' of pre-printed stationery) sticking somewhere.
S. Mohan
Canon dr 7580 error code E30
E30 is a Error related to Exhaust Fan. Pls check if the Fan is working, replace if required. If the scanner was used in a dusty environment, the dust can clog the free movement of the blades. It may require cleaning.
S. Mohan, Chennai, India
Canon dr 7580 erroe 32
If the main board (CPU PCB) not installed properly you get this error.
S. Mohan
Canon dr-7580 error 32
According to the service manual if 6080 and 9080c cpu/motherboard are interchanged this appears.
2helpful
3answers
Canon DR7580 error code e31
E31 refers to abnormalities in mechanical Counter. Check if it is installed properly. The scanner can work without this also.
I have a canon dr-7580 with a P00 error. I've blown it out but no paper found. what next
S. Mohan
2answers
Canon dr-7580 scanner how to initialize cis
If the Black lines are jaggered and are vary in size with different levels of brightness, then most likely it is scratch on the glass. If the lines are sharp and perfect and does not change when different brightness is chosen, then it could be failure of CIS module (Try this under B&W mode). To the best of my knowledge there is no concept of initialising the CIS, you may need to clean the Shading sheet.
2answers
Canon Dr-7580 not scanning two sided.
Check if you have chosen the 'duplex' option.
S. Mohan
Canon dr 7580 is not scanning multiple pages.
Check if you have selected 'multipage' option. Then you will get only a single file, but with multiple pages.
If your question is that the second or subsequent pages are not pulled in for scanning, then you need to change the rubber rollers.
S. Mohan
Imprinter won't work on DR-7580/9080C
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
old marine
old marine
ZJ Limited
ZJ Limited
