Its pretty easy really but you must reinsert the stabilizer bolt before you move it.unplug and drain everything. remove inspection panel on the rear and the pump is plain to see its the thing all the hoses are coming from. usually its a nickel stuck in there where the intake hose is. TIP! take pics as you go with dig cam or cell so you dont get lost in the woods good luck you can do it!
the Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
