Master
- Posted on Oct 17, 2011
Re: How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
Disconnect the antenna or cable
connection from the television's "VHF," "Antenna In" or similarly worded
port if it is connected.
Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
5
Plug the coaxial cable coming
from the cable television connection outlet into the second coaxial port
on the splitter. Use the port next to the one you used to plug the
television antenna into.
6
Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
7
Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
8
Plug in the television set and turn it around so the screen is facing you.
9
Use your television's remote
control to access the "Menu," "Setup" or similarly worded function. Or
press the "Menu" or "Setup" button on the front of the television.
10
Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
11
similarly worded function, then set the input to "Antenna" and perform
an "Auto Scan" to locate all available broadcast channels. Your
television will locate both broadcast and cable television channels.
12
Scan the channels on your
television to make sure all available channels have been found. If you
are missing any channels that you know you should have, manually program
the channels into your television using the "Channel Setup," "Manual
PHILIPS antenna
Coaxial is Cable line to hook up on your TV
