This a problem with your Canon Easy-PhotoPrint EX Software you should do a fresh installation if you have a software discs supplied with it - uninstall software and all drivers then install software plus drivers. Finally update drivers through device manager in Windows.
Have look at this guide if you have no software discs and dont know where to start - https://www.canondrivers.org/canon-pixma-mp258-scanner-driver-printer-download/
SOURCE: everytime scanner option is selected an error message pops up
I Had the same issue, worked on it for weeks, was told it was registry issue, I reinstalled the software, said it was hardware problem....THEN I FOUND THIS AND as simple as it seems, IT WORKED.
Please follow the instructions below to help resolve this.
Note::
Click on the View tab, look for Hidden files and folders.
Select Show hidden files and folders option
Click OK.
you should now be able to see the Application Data folder continue in to the folder path above.
(You may have to follow the steps again to turn off the Show hidden files and folders feature. )
SOURCE: problem installing after resintalling windows xp
I would try uninstalling the HP printer software then reboot and reinstall the software.
SOURCE: Vicamon.exe has encountered a problem and needs to close
Have you uninstalled / reinstalled the driver?
SOURCE: Why am I getting error message for Microsoft Feeds
This is a problem with Microsoft's RSS Feed Reader. As most people use a different Reader (or don't use RSS at all) this can be disabled. Please follow the instructions below to disable it.
Open Internet Explorer.
Click Tools>>then Internet Options.
Click on the Content tab.
At the bottom, under the Feeds section, click Settings.
Uncheck all boxes and click OK.
Click OK to close the window.
Close Internet Explorer and reopen.
SOURCE: msftstp.exe has encountered a problem
msftstp.exe is a malware program. Make sure you scan using a good malware eliminator (malwarebytes is a very good free one)
So bottom line, you don't want msftstp.exe to be running and you need to kill it.
Iām happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
