1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End
of Toner Life) should go away.
4. close it all up and your done.
Basickly, Toner cartridge has two sides one side to refill the toner,
other side has two screws, this is the side you have to work on,,
A- Remove 2 screws,,Remove cover out (( SLOWLY )) do not loose ther Gear
or the Spring,,
B- Turn The Big white Gear Full Turn,
C-reinstall the gear back.
D-But back two screws,
Good Luck,, Some times you have to try it 3 or 4 Times,,
Aslo you can see it in youtube...
David J.
it's work. Thank you
changing toner
i did change it and it still says the same thing
