Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
129
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives you the information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Well, disconnect the wii fit board, reconnect the wii controllers (sync them to the wii) then disconnect 1 regular controller, and connect the wii fit board.
Hi, When trying to sync my wii board I pressed the sync button for longer than ten seconds. The instructions tell you not to do this, I have tried re-synching the remote but this wont work so I don't know whaat to do, can you help?
Hi there, I wrote the last post.... I tried again and it worked! Thanks a lot.
When trying to synchronise wii fit to wii console I think I did it longer than 10 seconds and now the wii remotes dont work at all how do I get them to work again.
Elaine
