My dear: Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved But: Don't try to enter a PUK code without knowing the right one. You need to call your service provider to get this code. It can be as many as 8 digits, and it is random. If you enter too many wrong codes, you can permanently damage the device. So Please You Go to Service office and Get the Duplicate Sim From Office Oprater Same Your No Problem will Solve
PUK code can be given only by your service provider which is specific for each and every mobile number. Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them. Go to the nearest service outlet of your service provider they can also help you. There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software. Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone.
1. First, get your LG Neon’s IMEI number by, typing *#06#. 2. The first 15 digits of output are your LG Neon’s IMEI number. 3. Call up your phone carrier’s support line and ask for an unlock code. 4. They will ask for your phone’s IMEI number and give you an unlock code in Regards,Kesav
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times, This code is OPERATOR specific and not phone specific and you have to call you operator and get PUK if PIN is blocked...
if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM
NOTE: You should ask your service provider,get the PUK, Else it can be found in the booklet given when you purchased the SIM card
One way is by going to your AT&T and tell them to unlock your LG Neon and when they do ask them if they can reset it so you wont have any more problems with the PUK code.
Normally you get the PUK code togetther with the SIM card. The PUK code is used to access the phone if the PIN code is forgotten. The PUK code is a long number. The PUK code normally writhed in the same place as the PIN code
Normally you can also access this number through your phone provider/ call provider
PIN CODE and the PUK code is SIM dependenet and not phone dependent
remove the harmonic balancer. you have to have a special puller. it is a three prong puller that uses a center pin. you cant remove it without this puller.
