Toro Lawn Mower With Toro Power Tools Logo
Anonymous Posted on Oct 21, 2011
Toro snowblower wont start.I have a toro ccr powerlite that dosnt seem to be getting fuel from the fuel line into the carb. I took the fuel line off and fuel is getting to the carb so then i removed carb and blew in where fuel goes in and can tell theres nothing going in.is it blocked and waht can i do?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 22, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1909
Points
Reference the Toro snow blower. It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now. Hope this works for you.
2answers
Toro CCR 2450 Snowblower has new plug & gas but will only start with added starter fluid then will run until trying to start again.
Question edited for clarity.
When you put it away at the end of last snow season, I expect you just rolled it to the corner of the garage and left it until now? The two stroke gas in the carburetor, went bad and gummy. It starts on starter fluid because no gas is coming from the carb.
https://www.google.com/search?q=toro+ccr+2450+carburetor+cleaning
Jan 19, 2024 • Toro Garden
Toro CCR 2450 snowblower won't start.
Try a short burst of starter fluid into the carburetor and promptly pull starter. If it runs for a couple seconds and quits then the carburetor is not delivering fuel.
If it doesnt run on starter fluid then either flooded, insufficient spark, or poor compression / crankcase leak.
Oct 26, 2019 • Toro Garden
NEED THE PART # FOR A NEEDLE AND SEAT TECUNSCH CARB. SNOWBLOWER # ON CARB.16622J60 BLOWER MODLE 38415
We have no parts here. I suggest you contact a local dealer parts dept for the product.
2answers
1helpful
3helpful
Toro snowblower wont start. seems like the fuel isnt getting into carb.how and what can i do
Reference your toro snow blower. does it start and run for a few swconds then die. if so It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now.
I need a manual for aToro CCR Powerlite 3horsepower snowbloer
Hi kfshuler
Sorry, I could not get your user manual for you.
I needed your model number to get the user manual for your Toro CCR Powerlite
Go to the Toro site and put in your Model number at this website, and download your FREE user manual...
Please take time to rate me
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
Sep 13, 2011 • Garden
LEFT GAS IN SINCE LAST YEAR TORO CCR POWERLITE NO GAS COMES OUT WHEN I TURN IT UPSIDE DOWN
Sounds to me that it leaked out.you might want to check the fuel line for leaks.
TORO CCR 2000 WONT START UNLESS YOU SELF PRIME THROUGH THE SPITCUP ON THE CARB THEN SHUTS DOWN I RAN A FUEL LINE FROM THE CARB TO A JAR OF FUEL STILL WONT **** FUEL THERE IS A MIKUNI CARB ON IT I GET GOOD...
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 24, 2009 • Garden
Toro powerlite ccr model#38175
seems to me you have water or dirt in you carb pull the carb off take the bowl off clean it real good try to do so over a bowl or bucket to see the fuel that comes out to determine if its water or just dirt
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
