Hola tengo problemas con mi sansa de ese aviso "load main image failed switch recovery mode" ya hice lo que le recomendastes a la otra persona - Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
pero a mi me da un mensaje de error que revise la version...
sera que es otro archico el que debo usar porque mi sansa es un e280 ???
