HP LaserJet 4 plus Printer Logo
Posted on Sep 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp laserjet 4 plus printer cannot print excel files
The printer can print word files and that too when i select AUTO SELECT in the tray column in page setup menu, but this menu is not available in excel page setup and when ever i give print command it gives error PC LOAD LETTER. ive adjusted the paper size to a4 but it only prints doc files...help
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 115 Answers
  • Posted on Oct 23, 2008
Anonymous
Expert
Level 2:
Mentor:
Answers
115
Questions
Helped
90834
Points
271
Wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Unable to print on network it is showing offline or load letter. How to resolve?
I can help you with your HP Laserjet 4 printer problem.
Ensure the paper is loading correctly from the paper tray by reloading paper and printing locally.
If the printer prints locally, then paper loading is not the problem. Select your printer from the Control Panel > Printers list, right click and choose Sharing to re-setup printer sharing.
I hope that helps.
How do is set third tray as my default tray?
In your printer preferences, changer paper 'source'. For this specific printer the HP Laser Jet 4: Under the "General" Tab there is a button LEFT of "print test page". Click on that [printing preferences], the next window that comes up, click on the top tab that reads "Paper/Quality" and select 'lower tray' or your tray of choice.
-Feelrusted@hotmail
How do I manually feed odd size paper for printing
On the Configuration Menu select MP Tray. Set it to Manual. Just feed the paper in the manual tray.
1helpful
2answers
Prints from Manual Tray instead of Tray 4
Open a document. Select File>Page Setup and change the Source to Tray 4.
Or...
Try to print something. When the Print window comes up, select Preferences. On the Print/Quality tab look for the drop down menu labeled "Source is:" and change it to the tray you want. Click on the Save button.
Here is more info from HP:
HP M9050 Tray Configure
1helpful
I HAVE LASERJET 4 PLUS. WHEN I GIVE JOB FOR PRINTING THE PRINTER DISPLAYS A MESSAGE AS PC LOAD LEGAL. PLS HELP ME IN SOLVING THE PROBLEM
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Paper trays
You will find the answer in Printer properties.
I think you have to turn off auto select.
1helpful
HP 4700 not printing excel files correctly
Only solution I've found is to print to pdf, then send the pdf to the 4700. pdf995 works quick & cheap
Only first page prints out with HP LaserJet 4 plus
i would say reinstall the driver, wouldnt be a schoolboys trick even sometimes the schoolboys know more than the teachers when it comes to technology.
Try the machines with a seporate machine thats a freash install and see it does the same thing, this a driver issue, and sometimes the students can hack into the machine and asking the printer to just print just one page of the document, you can select pages in a print box in word / Internet explorer for example.
And you can ask the printer to print two pages onto one page.
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Happy Laser Jet 4
Hi there you could try the following see if this helps.
  • Click Start
  • Select Printers and Faxes
  • Right hand click on the printer Icon
  • Select Properties
  • Select Advanced located at the top of the window
  • Select Print Processor
  • On Right side of window select Raw [FF auto]
  • Exit all open windows then test
If the same problem repeat above and select different graphic mode. Hope this works for you
Thanks J
k24674
Grand Canyon Tech
Grand Canyon Tech
