Sanyo mod dp19241-no pic 'Digital channel signal strength is low' is on screen
    Top Expert:
  • Televison & ... Master
  • 76,171 Answers
Hello
As the set reports, the strength of the digital signal it gets may be weak. An other possibility is the fault with its digital tuner itself. Check the digital signas strength first. You can contact your cable provider, and ask them to check the signal strength at your premises's cable end. If it found satisfactory, there is no other way than replacing the digital tuner of your TV.
It is a skilled work, and should be done either by any expereinced serivce technician or by the authorised service center for Sanyo at your town. OK.
Posted on Oct 23, 2011
6ya staff
SOURCE:
My screen shows this message.... "Digital channel signal strength is low." what do I do?
buy one of those 15 or 20 dollars amplifier to step up the signal. Radio Shack is gone. Try the internet.
Feb 14, 2018 | Televison & Video
Cannot change channel on my Dynex DX-L26-10a TV
Try checking the signal strength then run the scan again.
Checking the DTV signal strength
You can check the DTV signal strength to determine if you need to adjust your antenna or digital cable input. The higher the signal strength, the less likely you are to experience picture degradation.To check the DTV signal strength:
1.Press MENU. The on-screen menu opens.
2.Press < or > to highlight Channel, then press v. The Channel menu opens. The DTV signal strength is shown at the bottom of the menu.
3.Press EXIT to close the menu.
Oct 26, 2012 | Dell Vostro 200 PC Desktop
Insignia NS-30HTV 30 screen is black on all inputs, and says digital channel signal strength is low, can i fix this?
you need to get a digital aerial first .then you can sort out any other problems from there
Oct 03, 2012 | Insignia NS-30HTV 30" TV
We just bought a Sanyo LED tv and channel ten is not found when auto tune is done someone please help!! :)
Test the signal strength using analogue tv mode and teletext page 284. If this shows no issue open up the TV tuning menu and use 'Manual Tume' until the missing channel shows on the screen and then Save.
Apr 03, 2012 | Sanyo Televison & Video
I have a lg model 42px5d tv which will not tune to all digital channels I have been told there maybe a fix for this but not sure where to find it
Usually, with this problem, it's due to low signal strength. Digital TV needs a good quality DTV antenna. GOOD QUALITY cables and connectors are also a good idea. If you live in a low signal strength area, u may also need an amplified antenna.
Aug 02, 2011 | LG 42PX5D 42 in. Plasma HDTV
My tv says digital channel strength is low
Hello
If you are using this TV with Cable connection, the strength of cable signal is low. Contact the cable operator and ask him to put a signal booster at your premises. If you are using it with On Air transmissions receiving, include an antenna signal booster at the mast of your yagi antenna on roof. OK
Jul 05, 2011 | Toshiba 36A40 36" TV
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't view my digital channels
Get an outdoor antenna. Digital signals very rarely reach indoor antennas unless you are within ten miles of the signal origin.
May 12, 2009 | Broksonic CTGV-5463TCT TV
Just bought new 32" sanyo model dp32648. Can't get the picture or
If this problem is happening on a regular TV channel and does not appear when watching an HD channel or while watching a DVD then most likely you have no problem at all. What you are seeing is actually the LOW Definition signal sent for regular TV programming that used to look pretty good on a small tube style screen but now is enlarged on a screen capable of incredible accuracy and is displaying all of the poor quality attributes of standard definition TV.
Feb 25, 2009 | Sanyo DP32648 32 in. LCD TV
Televison & Video Logo
550 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
