Question about Meade Optics
I've got a Meade telescope LX90 ACF. When I connect The Meade Autostar handbox does not show any display when switched on, I can't operate any function with it. I've checked the curly cable that connect the Autostar to the telescope and the voltage from the power supply, both are OK.
6ya staff
SOURCE:
Anonymous
SOURCE: MEADE LX90 TELESCOPE
Had the same problem. Took it to a dealer and we put a new controller on but the funny thing was that my old controller worked fine on another scope but it would not work on mine. Agreed with "Guest" above - Mead's after sales service is bad.
Posted on Apr 08, 2008
Anonymous
  • 1027 Answers
SOURCE: meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
Posted on May 22, 2008
Anonymous
  • 73 Answers
SOURCE: vista will not work with autostar 494
I did some research on meade 506 astrofinder software
Read this...
Customer Review:
Rating: stars-1.0.gif
Summary: outdated software
The software this kit comes with is old and outdated. It is not supported by Windows XP nor Windows Vista. The latest supported version of Windows is Windows 98.
It also appears that the included software is a limited trial software. It is limited to the included 3 catalogs (star maps). The complete set of catalogs must be purchased additionally at quite some expense.
The cable connection kit couldn't be reviewed because it was missing from the package I received, but keep in mind when you order this kit, that neither Windows XP nor Windows Vista support serial ports anymore. The additional USB to serial adapter would be required.
That last line would suggest to me that if one had a USB to Serial adapter it might work? but I really do not know for sure. checking into some more stuff...
Found another article that states "It requires a PC running Windows 98SE through Windows XP. It will not run under Windows 95 or earlier, nor will it run under Windows Vista."
OK I found this site, you might be able to make some sense of it. But I did read in there that they do make USB serial adapters that will work with Vista OS.
Good Luck and happy star gazing! If you find something new out there maybe you could name it after me if you get it working. lol
Posted on Mar 07, 2009
Anonymous
  • 1027 Answers
SOURCE: how to replace internal clock in lx90 8
Probably just needs a new lithium coin battery - located behind front panel.
Posted on Feb 21, 2010
dennis bullard
  • 4090 Answers
SOURCE: Meade Autostar handbox
removeformat.gifBecause this is a new purchase i would suggest getting the handbox replaced under warranty. If the guy was rude, then mention this to their management. There have been quite a few prolems with meade gear on our site here. Handbox included.
If you are up to it you can open it up. if so inspect the board for damage, shorts or loose solder joints. Some of these things can be repaired, some cannot. On this last statement it would seem sensible to get the replacement then start again from scratch. I have found about 7 recent problems with this unit, so be aware this is not a fault free unit.
nettiser
Posted on Feb 27, 2010
My question is, I have a Meade Autostar #494 How do I see through the lenses?
The 494 is the HAND CONTROLLER NUMBER--- not the telescope. What Meade telescope do you own??
Aug 20, 2011 | Meade 494 AutoStar Telescope Control Unit...
Can I just swap out my meade 492 motorized mount remote for a used 494 autostar remote or 497?
It depends on which model Meade telescope you own-- you never said?
Yes you can swap a 494 for another 494-- but we need more information to be able to say a 497.
May 11, 2011 | Meade 494 AutoStar Telescope Control Unit...
My telescope/autostar not working ,will only display startup info on handbox ,then nothing happens !.
This is sometimes caused by a bad hand controller cable and or corrupted firmware in the hand controller.
Get a new cable first and try it-- if this does does work then RESET the hand controller and reload the firmware using the proper computer cable and Autostar Updater Version 5.9 available here:
http://www.meade.com/support/auto.html
http://www.meade.com/support/Win7_ASU592_Installation.pdf
Aug 31, 2010 | Meade LX200GPS Telescope
Nothing seems to work on my LX90
You may need to purchase a new hand unit.
go to meade.com for purchase.
May 15, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
How to replace internal clock in lx90 8"ACF. Meade LX 90 8" ACF with UHTC
Feb 21, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
Etx-ls update to 1.2g failed, how to i restore or try the update again the autostar iii handbox does nothing
Easy.
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software. To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar.
Oct 08, 2009 | Meade Optics
No power to the autostar
You may want to try a new cable to the Autostar.
Nov 02, 2008 | Meade LX90GPS: 10" LX90 GPS Telescope
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
nettiser
Sep 15, 2007 | Meade 494 AutoStar Telescope Control Unit...
Optics Logo
80 people viewed this question
Top Meade Optics Experts
Gep Pep
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
