My Sony Tv has a blue discoloration line at the bottem of the screen. Also there are some 'glitter like specks' on the screen. What could be the problem?
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
SOURCE: sony kdf-e60a20 problems
Replace the main lamp( sony XL-220). Step by step instructions in owners manual, takes about 10 minutes and is very simple.
SOURCE: LCD blue on bottom screen
replace the cold cathode(s) that lights your display it is like a small florescent lamp
SOURCE: I have a KDF-55E2000 Sony Grand VVEGA Color Discoloration
Bad news: The issue can only be solved by replacing the optical block for the TV. This was a defect in the design of this TV. Replacing this part is very expensive (over $1000) and time consuming (need to take whole TV apart).
Good news: Sony extended the warranty for the optical block for this model. They are covering the cost of parts and labor for this TV. Contact Sony to have them refer you to a authorized service center near you.
