Question about Ricoh Aficio 1085 Laser Printer
Copier problume. there is a sc coed coming again and again after reseting the code is sc 550
  • 162 Answers
Press the Clear Mode key.
Use the keypad to enter “107”.
Hold down Clear/Stop for at least 3 seconds.
The Copy SP or PM Counter items are displayed. The
Printer SP and Scanner SP are also available if installed.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
After replacing the web with a new
one, reset SP1902 001 to 0 to
release SC550.
Or press feed there is the 1902 code.
Posted on Oct 21, 2009
    Problem Solver:
  • 5 Answers
return SP1-902-1 to 0. Then, the SC will
be cleared.
Posted on Oct 19, 2008
    New Friend:
In Ricoh 7950 Code SC 902
Posted on Aug 16, 2011
6ya staff
SOURCE:
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
How to reset drivers on mutoh sc 550
Have you checked it is not programmed in the metrics scale (cm) instead of the imperial (inch) scale.
Maintenance manual is available at this site
http://83.145.206.11/profiles/Ohjekirjat/Mutoh/SC/Mutoh%20SC%20manual.pdf
Check the Power on instructions on page 31 of user manual.
http://83.145.206.11/profiles/Ohjekirjat/Mutoh/SC/Sc_manuaali.pdf
Sep 16, 2014 | Office Equipment & Supplies
How to reset SC 302 code ?
sc302 is usually PCU or charge roller.
As you say you have recently replaced the Drum/PCU, is the drum turning correctly?
Check charge connectors and connectors on the back of the pcu. To reset that code, simply turn main power off and on again. If problem comes right back....the machine detects the cause still exists. May be an issue with the HVT.
Sep 01, 2014 | Ricoh RICMP201SPF AFICIO MP201SPF,...
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
Afficio 1013 has error 550 problem
SC Code 550 - Standby temperature error 1
Symptom: Fusing temperature failed to
drop to expected level within a
given time (15 seconds, 15
minutes, or 25 minutes,
depending on mode) after
entering standby or low-power
mode.
Possible Cause:
• TRIAC short
• Fan not running
May 05, 2011 | Ricoh Aficio 1013F Copier
Sc code 550
sc 550 is main motor error. i think the main motor needs replacing
Dec 06, 2010 | Ricoh Aficio 2015 Copier
I have a ricoh aficio 2035 that reads error sc 546 problem
It is fuser code, to reset enter the sevice mode by pressing All clear 1,0,7 & Keeping Stop button pressing, Press the copy Mode, then OFF & ON the m/c, the code will cleared.
Aug 17, 2009 | Ricoh Aficio 450 Copier
Sc 542-00 trouble code
SC542 is a fuser error code and can ONLY BE RESET by a tech. Type pressing clr mode (button) then 107 then press and hold CLR Stop until a menu pops up. turn offf main power then on again. If there is no serious problem the code will not come back. IF it does call a trained tech. DO NOT CHANGE ANY SETTING in the menu that comes up after pressing in the code. YOU COULD RENDER YOUR COPIER INOPERABLE!!!!!!
Mar 27, 2009 | Gestetner Copier
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
Ricoh Aficio 1085 Laser Printer Logo
1,229 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
