Question about Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b
Symbol Spectrum24 4131 Access Point - configuration after reset. I reset my AP but now I can't access it by ethernet (10.1.1.1 does not answer!) Do I have to use the serial interface? Any suggestion please!
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: reset to default a symbol spectrum24 ap-3021
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Posted on Sep 17, 2008
Anonymous
  • 52 Answers
SOURCE: Does the Symbol AP 3021 Access Point accept WPA encryption?
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
Posted on Feb 09, 2009
Anonymous
SOURCE: Default IP address for symbol spectrum24 ap-4131
Try 10.1.1.1
Posted on Apr 23, 2009
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
Mar 25, 2014 | Symbol Spectrum24 4131 Access Point...
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
This AP is in network x.x.102.0, which has it's own DHCP server. Only lan-port and WLAN are used on AP. I need this AP not to have it's own ip-adress, but devices, that connect to it,using WLAN,...
Ideally, there shouldn't be any configuration needed. Access points are transparent and only work as a bridge between wireless and wired network so devices should obtain their IP info from your DHCP server not the access point by default.
If you face problems, then there might be a DHCP server in the access point, disable that.
good luck
Othman
May 20, 2011 | Symbol AP-5131
I am not able to login my new dwl-2100 AP acess point
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi If you are still not able to access with above ip then press RESET button for 10 seconds it is in back side of router then all settings defaults then you can access it with above ip . Let me know if you need further assistance. Thanks for using FixYa.
Oct 09, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
How to reset orinoco ap 700
See the AP700 Hardware Overview below.... while the router is on.. press and hold the reset button (hole) for about 10 sec, using a paperclip.. the simplest way to restore your default setting..39f23e8.jpg
May 12, 2010 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Feb 09, 2009 | Symbol Spectrum24 AP 3021 802.11b
Reset to default a symbol spectrum24 ap-3021
Plug in the power.
Wait 15 secs.
Apr 09, 2008 | Symbol Spectrum24 4131 Access Point...
Unable to get connected to Belkin f5d6130 AP
You need to be connected using  wired Ethernet (PC's LAN card to Router's Ethernet Port (at the back)).  This is the preferable INITIAL way to configure the router before going wireless. Also it would be to your advantage to initially set your PC (that will be used for configuring the router)  to "Specify an IP address" (static settings) and not "Obtain an IP address automatically."
For a PC connected via UTP networking cable attached to a Belkin F5D6130 AP, the networking settings could be:
IP Address 192.168.2.2
Subnet Mask 255.255.255.0
Default Gateway 19*2.168.2.1
DNS Server 192.168.2.1
Reboot
Post back results. Good luck and kind regards.
Oct 12, 2007 | Belkin (F5D6130) 802.11b Wireless Access...
3crgpoe10075 status led blinking with no stop
hi ,,, i got yor problem. as ya said its not allowing ya to log nto it with security enabled. Ya can try to log into it with the ethernet cable as their wil be an ethernet LAN port onthe access point. I f ya know the default or the present ip of AP then ya can assign a static ip of the same range to yor computer like eg. ap is 192.168 .1.1 then your comp can have 192.168.1.10 and ya can log into it thru the ethernet cable and disable the security. i hope ya know how to assign a staic ip add to yor compuetr. or check the screen shots on brivers.com n select the "network connections" screen shots to assign a static ip address to yor' comp. feel free to chat with me on samrat101 thru yahoo or msn messenger or drop a mail on samrat101@yahoo.com for ny wless n ipphone issues -- take care ,, samrat
Nov 23, 2006 | 3Com OfficeConnect 802.11g/b Wireless...
Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b Logo
258 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
