The power went out while I was washing a load on my Maytag Epic Z front loader machine. The code is F-01 that comes up. I have tried to reset it by pressing the pause/ cancel button twice. Unplugging it for over 15 minutes, took off the hoses and then putting them back, unscrewed the back metal plate and took the top off to see if I could get the door open. All of these have failed me and my wet clothing is still stuck in the machine. There is still water in the machine which may be the reason for the F-01 reading. What are my options now?
How to Troubleshoot a Maytag Epic Washer Front Loader
Tip
Call Maytag for service if any of these procedures doesn't clear the code on the washer display.
Warning
Maytag makes several models in the Epic series and operating instructions vary. For model-specific troubleshooting instructions defer to the user manual that came with your machine or contact Maytag support.
Each model in the Maytag's Epic automatic clothes washer series has a computerized processing unit that displays error codes on a digital screen when something goes wrong with the washer. These codes help Maytag service technicians diagnose the unit. If you know the codes, you can troubleshoot the problem yourself, rather than request a service call, possibly fixing the issue yourself and saving you some money in the process.
Long Fill (LF) or Drain Problem (F9E1) Error Code 1.Press the power button to cancel the cycle.
2.Unplug the washer or disconnect power to the outlet its using.
3.Turn the power back on and select the cycle you wanted and press start.
Washer Problem (F--E--) Error Code
1.Press power to end the cycle.
2.Open the door to check for excess water in the drum.
3.Press "RINSE DRAIN & SPIN" if there is still water in the drum to remove that excess water.
Suds Routine (SD) Error Code
1.Open the drum at the end of the wash cycle.
2.Remove the clothes from washer, carefully examining them for damage from the excess suds issues.
3.Review your detergent uses to ensure that you're using the recommended type of detergent and the correct amount as stated on the product's instructions.
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
when my front loader was giving me the f-01 there were three diffrent times one was water pressure 2 was soap wat to suddy 3 not enough power which is the most common another was off balance and load to heavy funny they all have the same err code #
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
