I bought an Akai CF2791 27" TV from my friend whom it worked for just fine. now when i plug it in and turn it on, the green power light comes on but no picture or sound. no static or snow at all. please help!
I have a troubleshooting procedure file who is in PDF format , i don't know how i can send that to you. Any way if you are a technician , send me a small message to my email so i will send you all the information attached to the message which i will send back. Thks
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
I did it tonight, worked on the Akai for two hours. I don't have any electronics experience and just followed what these guys did and spent less that $20 for parts and supplies from Radio Shack. Bought three different capacitors, mine was 1000uf 35wvdc 85+, a solder kit, and a desoldering vacuum tool. My soldering wasn't the best, actually the worst I have ever seen but I figured if it doesn't work, I could care less anymore. Apparently it worked. My first TV fix and i made it work! Follow the instruction here: http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Does the sound not work either? If it does then the backlight in your lcd screen has went out and your better off buying a new one because it is more than the tv is worth to fix it. Just start running through the imputs with about a 5 second pause between as this tv takes a few seconds to switch imputs and make sure you have cable or something connected to it the imput button is the second one down from the power button on the bottom right side of the tv. But if you dont have sound and it just seems completly dead most likely it probly got hit by lightning and slowly quit. Or maby you need to just buy a power supply if you dont see the green light anymore. Worst case senario your tv just got up and quit or maby it burned it self up from getting to hot. You can get a power supply on ebay for as cheap as 34.99. Hope this helps.
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
