SOURCE: Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
SOURCE: I have a Peavey PV 115 Speaker...The horn works
Check the resistance across the woofer connection points. Using an ohmmeter, you should se around 6 to 8 ohms. If there is no continuity, you have a blown speaker.
