Well if it won't rinse it won't pump out wither right? The pump is mounted on the motor. The motor won't pump or spin if the lid is open. I would check the lid switch
When this pump is going counterclockwise the water stays put. The machine agitates.
When time for rinse the motor goes opposite direction. If the lid is open the washer will not spin or pump out. I suspect you must have a lidswitch issue. Here is a video which shows how to check it without guessing
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hello Sandra,
The most proable thing wrong why it will not rinse is going to be the water inlet valve...all rinses are only cold water and it sounds as if no cold water is coming in to rinse the wash load.By replacing the water inlet valve that will very likely repair the washer.
The part number for that valve is 285805 it could be purchased at your local applinace parts store or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
This youtube video will show ya how to replace that inlet valve
http://www.youtube.com/user/RepairClinic?v=Fk4puRv3Vk8&feature=pyv&ad=5457342101&kw=washer%20valve
GENE
