SOURCE: red light flashes 8 times
The red LED blinking 8 times is an error code for the service technician. There is nothing you, the consumer , can do to remedy this problem. Your set will have to be brought in to an authorized Sony repair center.
C-Dog
SOURCE: sony model kp51ws500
Yes common problem it seems with these. I can help you get the set working but this fix only prolongs the inevitable so I'm told. (more about that at the bottom) Please read entire posting before starting. You will need to take off the front panel, there are 2 screws towards the bottom on each side behind little pop out plugs. Once those are out take off the panel (pull from bottom, sometimes the round clips at the top come off, either glue them back on the panel or leave them out). There are wires attached to the panel, you can either unhook them or just take them out of the "twist tie" holders and move the panel out of the way to the left. You will now see a thin panel. Remove this one also. Once that is off you will see the bottoms of the 3 glass tubes and on the "floor" of the set there is a group of 6 small knobs. This is called the focus block. Each row of 3 knobs are labeled either screen or focus, also, there should be 3 letters R G B (Red Green Blue). (We won't be adjusting the focus knobs).You will need to adjust the Blue screen knob (on my set it was the bottom left knob). If the set will stay on for a little bit you can adjust it with it on. Once you have found the correct knob (don't worry about the white paint) turn the set on, once you see the picture slowly turn the blue screen knob counter clockwise until the blue diagonal disappear. Be careful not to turn this knob too fast while the set is on. Keep in mind, it may take a little bit to break off the paint. You will see the screen turn back to normal as you turn the knob. Adjust it just until the lines disappear This should solve your problem. If the set won't stay on, with it off turn the knob about 1/8 turn counter clockwise then turn the set on. Once it is on you can fine tune it. Adjust it just until the lines fade out of sight. (You may have to adjust back the other way until the lines show up and then back it off again). Remember to turn the knob slowly. I have heard people getting charged a lot of money for this. I was also told that this is compensating for a dying component(s) all I know it has bought me at least a year. I also read that someone has gotten several years out of there set w/o repair just by doing this adjustment whenever its needed. (once the lines start presenting themselves). I can't see spending big money on these sets when you could put it towards a new set so I will keep it going for free as long as I can. I hope this works out for you. I'm tired of typing so good luck and post if you need any more help. BTW this adjustment works if this symptom presents itself in green or red also. Just substitute the blue knob to the applicable color. Now go put your TV back together :)
SOURCE: KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
SOURCE: sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
