Question about Garden
Need instruction on how to adjust carberator - Garden
  • 2,239 Answers
Adjusting carbs on chainsaws is not to be taken on lightly, there will normally be three screws, an L screw, an H screw, and an idle scre, the L screw will increase the fuel mixture from idle to half throttle ( they are fuel screws not air screws ) the H screw will adjust from half throttle to maximum revs, start with a base setting of between one turn and one and a half turns out, start the saw and warm through, allow it to idle, if need be increase the idle screw to get an idle, turn the L screw in slowley, the revs will increase as the mixture leans off, it will reach a point where it starts to die, now back it off a quarter of a turn, blip the throttle, the saw should pick up clean, if it has a flat spot increase the L screw slightley, now set the idle so it idles without the chain moving on the bar, now screw the H screw in to get full revs, be aware this should be set with an engine rev counter, do not exceed the manufacturersmax revs, hobby saws normally run at about 12500 rpm with an idle speed of 3000 rpm.
Posted on Oct 27, 2011
6ya staff
SOURCE:
Please assist me in adjusting my carberator on a arctic cat 400 atv
Bring extra main jets with you. Keep an eye on your spark plug. if it starts looking like its burning whiter you need to bump up your main jet size!
Aug 31, 2014 | ATVs
How to adjust a carberator on a 1979 datsun 310
Screw mixture inwards until the motor starts to cut out then back outwards until it smooths . Screw has a spring on the thread.
Jul 26, 2014 | Vehicle Parts & Accessories
My powermate rear tine tiller is getting gas into the oil it will start and run as long as im am putting fuel into the carberator once i stop putting fuel the engine stops what is the problem. the til
This sounds like the float is sticking in the carb causing it to flood . You need to take the carb off and clean it and put a kit in adjusting the float per the instructions
Jun 27, 2014 | Powermate 18 in. 196 cc 4-Cycle Rear-Tine...
Carberator adjusting
Many new units have a very limited adjustment possibility. This is due to EPA regulations. If the saw is hard to start, it may need to be richened up a little. Your dealer should have proper tool to adjust.
Apr 14, 2014 | Husqvarna 36 41 50 51 55 136 141 154 254...
I need instructions on for adjusting carberator settings on Mighty Mite chainsaw.
Before you make any adjustments start with fresh fuel in the saw. Dump out all the old gas and try starting with fresh fuel. The alcohol in the gas we have thease days draws water to to it. Water in the fuel will not burn.
Sep 08, 2013 | Garden
How to adjust carberator
Some Husqvarna carbs require a special screwdriver to adjust them, some just use a mall flat head tuning screwriver.
Screw both H and L screws in. Then turn them out anticlockwise the following amounts to return them to standard.
H 3/4of a turn L1 full turn (Chainsaws)
Some equipment like blowers and strimmers are:-
H 2 1/4 turns out L 2 1/4 turns out
Nov 03, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Runs only with full choke
clean carb,then adjust, do not use low end gas,(to many contaminates.use carberator cleaner in gas(read instructions, small tank)
Aug 30, 2012 | 1985 Honda VT 500 C Shadow
I have a MAC 3516. I runs starts fine and runs for a few minutes at high speed (have made a few cuts), but sputters and dies. It will start again, but when I try to increase speed it dies. I have...
Try checking the fuel filter in the tank for plugging. Also, check the condition of all of the fuel lines for decay or other damage. You won't be able to adjust the jet settings if the screw heads are 'D' shaped--only authorized service dealers have the necessary special screwdriver. Try removing, then replacing the fuel cap when it quits--if the vent is plugged, it will starve the carburetor after running a while. If it works well at first, then it is not likely that the jets are mis-adjusted. Hope this helps!
Oct 08, 2010 | McCulloch Garden
New carberater and a mechanic needed!
Even if you do it yourself you need to adjust it.I would get another mechanic to look at it also.Have you tried cleaners? 1 type you add to the gas the other you remove the air bonet and spray into the top of carb while running (have someone press on the gas lightly so you don't stall.Have you tried to increase the idle via the adjusting screw? has the auto choke been tested..adjusted? Good Luck.
Sep 17, 2009 | 1984 Honda Prelude
Need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Jul 11, 2008 | Electrical Supplies
Garden Logo
369 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
