SOURCE: Servicing Hobart A-200
these mixers dont use oil,they use grease.you will have to open the transmission to change the grease.any ? let me know im a hobart tech.
SOURCE: New (old) N50 ML-4749
You should be able to purchase the manual. I know that Hobart abandoned that policy a few years back -- unless they re-instated it. Call Mother Hobart and ask. 937-332-3000
There is a few tricks to these units, it would be tough to convey here. But here goes...
Remove back cover. Loosen 6 or 7 screws around outside of motor windings. Thump the nose of the mixer downward to break the seal. Watch for spacer washers where shafts go into motor case. Remove spring. Remove idler. Remove shifting guide. Remove gear assy. Leave beveled gears in place if possible. Clean. Use Darina II grease. (20 oz) Clean and permatex "seal". Tighten mounting bolts. Adjust set screw at back of planetary. (Double set screw. The first one is to lock the adjustment.) Test in 1st and then 3rd while turning the set screw. You just make it quiet for a proper adjustment.
Good luck -- Mike
SOURCE: Hobart A200 Mixer not working
Sundance,
Please visit the corp website www.hobartcorp.com and click on the "Sign In" link in the upper right hand corner. You'll need to complete a brief registration form, but then you'll land in the Hobart Resource Center.
Hobart no longer manufactures the A200 mixer - but you can review and download a user manual and a parts catalog from the Resource Center on your mixer. That should help you understand the parts need.
We do sell replacement parts direct to end users, just visit our service website at www.hobartservice.com - and click on the "Locate on Office" link. You'll be able to contact your local Service branch to purchase a replacement part OR to have them take a look at the unit and provide a quote on fixing it.
If you have additional questions on Hobart products - please contact me at [email protected] .
Thanks!
SHerri
SOURCE: transmission oil
this unit uses grease if it is leaking out the grease has broken and needs replacing
