Question about Coleman Powermate Powermate 5000W Generator
Powermate 2500 generator only generates 80 volts
    Master:
  • 265 Answers
How to test your Electricity Generator AVR Brushes and Alternator on...
Need more advice? Contact us, we are always happy to help!
http://www.generatorguru.com/ask-the-guru/
Regards
The Generator Guru Team
Posted on May 10, 2018
6ya staff
SOURCE:
Anonymous
  • 13 Answers
SOURCE: Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
Posted on Sep 27, 2008
CarlGehrke
Carl Gehrke
  • 169 Answers
SOURCE: powermate pm0545005 generator engine runs but no power out
I posted a general "how to" about troubleshooting Powermates here.
Don't forget to rate answers you like,
Carl
Posted on Dec 05, 2008
Anonymous
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
Anonymous
SOURCE: I have a Coleman Powermate Pulse 1850 Generator.
If the generator hasn't been used for awhile the rotor may have lost it's magnetism. All you need is to re-excite it. There are several websites that explain how to do this. It's a good place to start.
Erick
Posted on Apr 04, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 01, 2009
My coleman 2500 powermate generater leak from top of carburater, help
The carburetor needs to be rebuilt - the float valve is stuck open.
Jul 05, 2014 | Coleman Powermate Portable Generator...
240 volt output of 3500 watt powermate generator measures 140 volts
Bad capacitor in the alternator field or a short in the rotor / stator
Nov 05, 2012 | Coleman Powermate Powermate 5000W...
Where is the fuel shut off valve on a coleman powermate 2500
follow fuel line from fuel tank to the carb if you dont find it it probably does not have one
Sep 04, 2010 | Coleman Powermate Proforce 2500 Generator
PF 2500 watt generator... Need plug and oil
30wt oil, probably a Champion RN4C plug. Could give link to a manual if part / model number of generator was provided.
May 17, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
Powermate model 544000 generator undervoltage
There are basically 2 possibilities that can cause this.
1) Enigne RPMs are too low. but, since you already played with the throttle, this probably isn't the case. RPMs should be about 3600 though.
2) The voltage regulator / capacitor has high ESR (resistance) or is bad altogether. Replace.
Jan 01, 2010 | Coleman Powermate Powermate 5000W...
I plug a 1/2hp drill and use it I notice if I use anything else it is low of power. I put a meter on one plug and drill on other, and it reads upper 80-95 volts with drill running
Please check the owners manual.and see if the 6250W is surge power or steady state...it is not unusual..for this to occur...possibly the generator needs to be adjusted ( sped up slightly )..do not let the 120 volts output exceed 126 volts...
Apr 30, 2009 | Coleman Powermate Premium Plus 6250W...
Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
Feb 07, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
133 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Sheldon Dedek
Shawn DuRee
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
