Question about Hitachi 43FDX15B 43" Rear Projection Television
My hitachi 43fdx15b powers off
It goes off but the red light on the front stays lit. It does this a few times in a row then seems to work ok after that.
6ya staff
SOURCE:
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: hitachi 43fdx15b
Try this procedure:
Adjust the green & blue CRT screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white picture. Now adjust each CRT screen so that you end up with a true black & white picture. Then adjust each focus control to get a sharp picture, and adjust each CRT focus one at a time for clarity by covering the other two up. Then go back into picture adjust and turn color half way up, you should see a better picture.
If you cannot get the blue & green to even out to a black & white screen you have other problems such as faulty CRT card on back of tube or it could even be that the video IC is faulty. If this is the case, then you may have to get a competent local technician to check the TV and get the necessary parts replaced. It could set you back between $200-$400, depending upon how many components need replacing.
You can also try a hard reset..Unplug all cables, including power from the back of TV. Wait for 4 hrs and reconnect them. Try and see if it works now.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 26, 2008
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: Hitachi 43FDX15B 43 in
You can try replacing the convergence IC's ...should cost you about 350-400$..Its your choice at the end of the day,,It could also be that the lamp is blown and you will need it to be replaced. Best option..call a tech and get a quote and then decide..
Posted on Jul 20, 2008
Anonymous
  • 108 Answers
SOURCE: Hitachi 43FDX15B has a red tint...
This can be caused by a few things. The red crt/picture tube is going bad, which it would have to be replaced, tube can cost anywhere around $195 and up, if it is available. Another problem can be a bad transistor or IC on the red crt circuit board. Either way it should be taken to a repair shop. The average cost for repair could be over $300.
Posted on May 27, 2009
Steve Yocum
  • 668 Answers
SOURCE: hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
Posted on Jun 30, 2009
Anonymous
  • 647 Answers
SOURCE: 43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Posted on Sep 26, 2009
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
NO RED COLOR ON A 43FDX15B HITACHI 52
3 reasons for this.
1st reason the fluid is contaminated and thats why u dont get red.
2nd reason no red drive possibly due to a bad colour driver on the base of the tube neck.
3rd reason the tube is out.
May 23, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Sep 26, 2009 | Hitachi Televison & Video
May 26, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Power light stay on
Sounds like you may have a sticking Relay S901 on the power board. Tapping the Relay may Make The Light Go On And Off. The relay part number is FJ00142 if you can find someone to work on the set for you as it would involve soldering in the new part. The number on the relay may be ALKS329 with the former part number being the Hitachi Part number.
Aug 20, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Wont power up
I have seen that symptom many times. Most likely, the little blue capacitor next to the horizontal output transistor has shorted and popped the main B+ fuse. This is very common in those Hitachi projection sets. These parts should be replaced by a tech familiar with Hitachi projection sets.
Aug 14, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 43FDX15B 43" Rear Projection Television Logo
50 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
