Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on Oct 29, 2011
My sony kp57wv600 will not turn off. none of the buttons on the front panel work at all what should i do ?
Level 3:
  • Sony Master 17,130 Answers
  • Posted on Oct 30, 2011
Sony Master
Level 3:
Answers
17130
Questions
0
Helped
3635553
Points
52372
If the set works fine except the fact that the customer panel controls are not working but the remote works with all functions, then the fault can be limited to the front panel assembly. This can be due to moisture build up within the panel, can be a fault in the tracks, the linking connection in the processor interface.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Oct 29, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470310
Points
19564
Hi Jimmy,
Have you try using remote commander? It seems the power button on your tv is broken. It could be on button pad, or cables connected to it. Can you try check it?
Regards
Sony KP-43t75 - Front panel buttons and IR sensor stopped working
TRY UNPLUGGING THE SET FROM THE WALL FOR 2 MINUTES THIS WILL ACTIVATE THE AUTO RESET WHEN YOU PLUG THE SET BACK IN.
2answers
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Buttons don't work but still plays cd
deattche the front panel and reattche it ;) hope it will work fine up to next year. :D
Removing green crt
More than likely you don't have to replace the CRT. Go to this blog for instructions for how to fix the most common problems.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
At the bottom of the page there are comments from users. There are several users that explain how to take off the front panel and where things are located. The model KP57WV600 is different than the pictures in the blog, including the fact that the order of the red, green, and blue adjusters are different.
If you try it and it's not successful and you still want to try to replace the CRT yourself, google KP57WV600 service manual and you can buy it for $9.99 and download it right away.
I wish you well.
Sony 27" wont turn off!!!!
It looks like one of the buttons on the front panel is stuck, base on the info you have provided; the volumen down button is stuck. The remote or any other buttons will not be operative until the fault has been remove.
I would suggest to try to press the Vol. down a few times just to see of it unlocks, if that does not work, the front panel assembly will have to be remove and try again if it works with the remote or manually.
The last thing to do if none of the above works, it will be to put a new switch.
Good Luck.
Sony kp57wv600
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
2answers
HD Picture fades and goes balck
u and i both need blue crt tube.i also need convergence fix...u probably will as well .just had repairman over and tubes will be hard to find ...unreal tv is only 4 yrs old /03
2answers
What's wrong with TV?
how many times does it flash?
i suspect a bad red tube
sony has a recall on the tubes
3helpful
8answers
Screen Turns Blue and shuts off
Go to this site, follow the instructions, and it may fix your problems. I did, and my tv is better than ever!
I was having this problem with blue. I was able to fix it, and now my tv works again. For those having trouble removing a different front panel, here is what I found on mine -
I own a KP57WV600. Removing the front panel is a little trickier on this model. You remove the 6-8 screws on each side behind the two speakers. You will access these from the lower rear/sides of the TV. Remove the small 2ft plastic pieces. Now from the front of the machine grab the entire lower piece (speaker covers & power/volume/chanel buttons) from the bottom and pull down and towards yourself. There are 4 slots that this piece fits into. I had to take off the lower back panel to see why it wouldn't come out. Don't pull to far because this lower front piece is connected to wires. I'd say you have about a foot of play. Now you can remove the fiber board panel and access the blue/green/red lower screws. When you adjust these, go a fraction of a milimeter at a time.
KP57WV600 Blue Screen (what is problem, how to fix, how much $, can I fix?)
It is some other problem........possible bad blue tube. Get it
verified by a skilled technician......definitely not an adjustment..
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
