SOURCE: Calibration (2 group head la marzocco)
press and hold the swirl button on the first group (far left) lights will blink. press the button you wish to program, once you reach the amount of espresso you wish to give press the button again then it will be stored into memori do this to the rest of the buttons on the first key pad. after you finished the first group the computer will automatically transfer the same programing to the second group. Good uck
SOURCE: Unable to programme La Marzocco
FYI - the flowmeters can get fried after lots of usage. Back in the day Starbucks used to put pieces of cardboard between the flowmeter and group head to prevent them from heating up. Aside from checking for scale you use test with an ohm reader. I think a functional one will reach 2.4ohm (or maybe 2.8). A broken one will post junk ohm information and bounce around. Replacing them is expensive so I'd just recommend usitng the semi-auto on/off switches. This info comes out of the big oragne Linea maintenance book.
SOURCE: Buzzing Espresso Machine
that noice is from your solenoid valve during brewing coffe.
SOURCE: Problems programming La Marzocco Linea espresso
Check to see if the program switch is turned off. There might be a switch in the inside of the machine, or on the front panel and you need the key for you have to go through the cpu board.
