Canon PowerShot A630 Digital Camera Logo
A
Anonymous Posted on Oct 29, 2011
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am not sure if pictures are being taken. I had a few older pictures that were perfectly viewable. I deleted them so I could check to see if pics were being taken. No new pics have shown although I can see a little grayish noise around the edges of the view screen.
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Oct 30, 2011
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1194632
Points
12483
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
I have a Canon Rebel t2i. The LCD screen does not display any images including menu items. How can I get it to work? Details below...
This appears to be a deeper problem than can be fixed with advice on here. I suggest you take it for a professional repair. Check the repair estimate with the value of the camera.
3helpful
New pictures are black field. cant take new pictures
It is known problem of ccd imager failure in Canon A70 camera and ccd imager will be replaced to get live view in camera mode to take fresh pictures.
Canon offers free of cost ccd imager replacement for A70. Click Canon CCD Imager Advisory for details.
Thanks.
3helpful
The view screen is black and you can't see what you're taking the pic. Battery is ok
If camera shows Menu item or any on-screen display in LCD but no live view to take picture then it can be either aperture problem or defective ccd imager.
And if you do not see any display icon in LCD then of course LCD section is bad or LCD back light is Off for some reason. Try to see faint image in LCD if it is totally blank by pointing good amount of light with flash light or some thing.
Camera auto focuses, shoots but the view screen is black
Check the playback menu that the review time has not been set to OFF. This will stop any pictures displaying on the back of the camera when taking them!
I leave mine at 2 secs which is long enough to quickly review and keeps the battery life up. If I need to review for longer, just use playback.
The flash won't come on if you have the camera in any of the creative modes (i.e. A-DEP, M, AV, TV or P). You can manually use it by pressing the flash button just above the lens release button on the front of the camera.
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 • Cameras
1helpful
CANON POWER SHOT SD750 DOESNT TAKE PICTURES BLACK SCREEN
Mine started working again. The only thing I can attribute to it is that I zoomed the lens in and out several times. The next time I turned it on, it worked. Go figure. I'll update if things change.
2helpful
Pictures are black
My 4300 works fine until this week. No picture display on the LCD screen. Settings like date, exposure, etc.. are fine on the LCD screen. Able to get into setup mode and the colour menu selection box is fine. This shows that the LCD screen is working fine. Prior to this happening, I notice that when I took pictures in zoom mode, the picture turn out to be orange. I suspect this is caused by electronic failure. Light entering the lens cannot be transmitted to the LCD screen. Some photoelectronic stuff had reached its MTBF (mean time between failure)? Is there a way to save this camera?
No display
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. It can also take pictures and you can browse them....
3answers
Black LCD screen and viewfinder in photo take mode
Sony (who bought KM) will fix this for free. http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
