It could either be a bad door switch or something stuck in the pump or a bad pump.if you set it to drain/spin will it drain out the water or does it buzz there?if it does drain i'd have to say you have a bad door switch.the model number you sent doesn't come up,you can unplug the machine,remove the hose that goes to the pump or run it before you unplug it and see if it's the pump making the sound or if the center of the pump can be removed to clean out the pump and check the pump for coins and junk,use a shop vac and vac out all the water in the tub and then lossen the hose or center of pump until water starts to leak out and vac it up as it comes out,check the pump and put it back together,add some water with a bucket or something and see if it drains out,if it doesn't drain and it sounds like the pump is making the noise you have a bad pump,if it buzzes and it's not the pump change out the door switch.the buzzing is electrical,things that could make this sound are the motor,the solenoids on the water valve or the door switch,if you can do some checks like see if it drains or try to find where the noise is coming from would be helpful.good luck and i hope this helps you out.
MY MODEL # IS LTF2A0FS0
still the wrong model number,did you check the pump yet?it doesn't matter about the model now,when you find the problem call your parts store and give them the model number off of the machine,open the door and look around the opening where the door closes into and you'll see the model number,give it to them and they will sell you the part you need.good luck with your washer.
model#LTF214OFSO
