Sony Playstation 3 (PS3) Console Logo
john wackeny Posted on Oct 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ps3 will not power up - Sony Playstation 3 (PS3) Console
Christian Shinsky
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on Nov 05, 2011
Christian Shinsky
Expert
Level 2:
New Friend:
Answers
69
Questions
Helped
11476
Points
188
Here is step by step trouble shooting
1) attempt to turn on the ps3
+you will see one of 4 things a green yellow red light
+flashing red light
+green light
+no lights
2) if you see a green yellow red light call sony your system will need service
3) if you see a red flashing light also call sony needs service
4) if the light is green turn off the system and one the light is back to red press and hold the power button for a series of 2 beeps (do not forget the one when you first push the button down) then let go (it might be a video issue)
5) if you still see no video and a green light check the cable you are using and try again on a different tv
6) if you see no power light call sony it needs service
these are genuine trouble shooting steps from sony technical support if you do have to call them be prepared to follow the same steps that lead up to service. thank you
Can the power supply on a PS3 be tested
Yes, best thing to do would be to go to a buyback games or check locally for information on testing a PS3 power supply.. Or you can google: How to test a PS3 power supply. good luck.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
PS3 320gb Slim No Power (No Lights)
You could always try a system reset:
Starting with the PS3 off... Hold Power button on PS3 for 10 seconds. When you hear the second beep, it has been reset...
4helpful
How do you reset your PS3?
You can reset the Sony PlayStation 3 to troubleshoot the gaming system or restart after a hard drive freeze. Resetting the PS3 will restore the PS3's settings to to the default factory settings. Consider backing up any data or custom settings before doing a system reset for the PS3 as they might be erased.
instructions:
  • urn off the PS3 by flipping the power switch on the back of the system.
  • 2
    Turn the power switch back to the "on" position.
  • 3
    Hold the power button while the PS3 is powering up until you hear three beeps. These signal that the PS3 has received the manual system reset command.
  • 4
    Prompt through the initial setup menu to continue resetting the PS3.
  • 5
    Select "Format" from the system menu to format and finish a complete system reset for the PS3.
  • 1helpful
    Try to sign in and error code 8071053D keeps appearing
    1. Turn the PS3 to standby power off.
    2. Turn off the power on the PS3 by using the power toggle switch on the back of the PS3 and unplug power cord.
    3. Restart your wireless router, if using one.
    4. Plug in the PS3 power cord and power on the PS3.
    5. Try creating a new connection on the PS3 by accessing the Network Settings menu option on the PlayStation 3.
    go for a minimum of 5 minutes in between each step to properly clear it
    i hope this helps you and please vote for me
    Ps3 troubles
    The PS3 is essentially a computer....Light stays on because its a standby mode retaining power for ps3 memory etc.....
    2helpful
    Japanese ps3 power supply
    US and Japanese power supplies are the same. The 60GB PS3's run hotter than any other models. I've never seen a power supply get hot, but if it is then it's probably a good idea to swap it since heat is the number one 60GB killer.
    I just created a blog that has a ton of usefull PS3 info and tips. Please check it out here:
    http://rescuetechla.blogspot.com/
    Power Button
    just install your ps3 demos on system use webbrowser on ps3 to download demos or store the ps3 canot be shut down by power button on system itself only from controller or turning back off then on hope this helps
    2answers
    Ps3 power supply cost?
    nutterbutter
    In regards to looking for PS3 powersupplies you have 2 options. You can do a search through Ebay and/or you can do some searches on the Internet.
    I got one the other day for $35 after shipping.
    Here is some links that I ran a search on. Note PS3 is also a term used in computer powersupplies so you will get some hits on them as well.
    http://shop.ebay.com/items/ps3%20power%20supply?_dmd=1&_sop=12&tt_encode=raw&crlp=1652236613_9405&keyword=ps3+power+supply
    http://www.google.com/search?hl=en&q=ps3+power+supply&aq=4&oq=ps3+po
    Let me know if you have any more questions and/or problems.
    Issken
    PS3 won't turn on
    hi Torgsrus.
    PS3 Light sequence
    The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
    No lights are on:
    When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
    If the PS3 does not turn on:
    · Make sure the power cord is not frayed or damaged
    · Try using another power cord, if available
    · Make sure the main power switch on the back of the PS3 system is turned on
    · If you continue to have issues contact our Technical support.
    Solid Red:
    When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
    Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
    If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
    Solid Green:
    When the power status light is solid green, this means that the PS3 is turned on.
    You should be able to navigate the XMB, play games, access the Playstation store,etc.
    To turn of the PS3, simply press and hold the power button for two or more seconds.
    If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
    Flashing Red:
    When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
    This may be caused by poor ventilation or the vents may be blocked.
    If this happens:
    · Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
    · If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
    · Leave the ps3 system off for 30 minutes to let it cool down.
    · If you continue to have issue, you may need to send the console in for service.
    Flashing Green:
    When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
    If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
    If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
    Flashing Green, Yellow and Red:
    When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
    When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
    Solid Blue:
    When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
    If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
    Flashing Blue:
    When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
    If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
    1helpful
    4answers
    Ps3 no power
    PS3 unit has fuses that probably failed. I wouldn't void the warrenty to try and change them yourself but this would be the place to start if you take it in for repair.
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
