Washing Machines Logo
A
Anonymous Posted on Oct 31, 2011
I have nec 4.5 kg washing machine,I was working fine till yesterday,today its not starting ,I tried to turn on doesnt happen anything. Please Help needed
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Oct 31, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1026377
Points
20216
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
  • Anonymous Nov 01, 2011
    I already check the power supply it was working fine.but machine didnt start,then i drain all water by removing pipeline. it didnt start immidiately,but next day morning worked all good....dont know what happen ...but i should get the service done surely...anyway thanks for your advice...atleast finally started...
Why is not running ?
Do not turn anything on if your home is not earthed . Turn off main isolater and contact an electrician asap.
1helpful
Nec nw891 washing problem
Check your drive mechanism further, something caused it to come unscrewed. I would go deeper and see if I could find anything that could be out of balance or worn, that would have caused the screws to come out.
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
1helpful
Till yesterday Seinnheiser rs 110 worked fine when i switched it today only one speaker is working i.e is right speaker.I thought batteries were weak then i recharged but have the same problem.When i tried...
  • The wiring has disconnected inside your headphones. They will not work unless you have someone re-wire the headphones for you. This happens after time with most headphones.
  • Please reply if you have any more questions. Good Luck!
I have LG washer & dryer 8 / 5 kg WD-14440RDS I could not start it its connect to electrical supply but after we washed clothes yesterday today we could not start??
Does it turn on? if so either the start button is faulty(LG will want to sell the whole board but the switch is fairly easy to replace) or the door lock.
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Washing machine not taking in water
could be air in line washer thinks no water try taking supply off and let air out till water comes out then put back on washer make sure you turn off first lol, and first check to see if the plumber turned supply off for washer by mistake .
4helpful
3answers
Washer not spinning or draining. Making LOUD grinding noise.
i started a load it aggetates but when it gets to next cycle it does nothing . i can hear timer switch to next cycle but it doesnt soin or drain .what can it be?
Top Washing Machines Experts
john h
