Exercise & Fitness Logo
Anonymous Posted on Nov 02, 2011
Reebok edge 2.2 treadmill stopped suddenly then blew fuse
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Nov 04, 2011
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4078091
Points
34431
1) Inspection if the fuse is the correct Amper and Voltage: example: you can not connect any FUSE less if they use 10Amp, not use 5 amp, or 15amp. That situation is delicated.
2) clean contact fuse, and retight the clips of the fuse, and tight the wire to the clip of the fuses.
3) The motor is Short or ground: Test with Some DVOM, maybe the winding is short,and need maintenance: brushes, grease, and clean, bearing. or the winding is faulty.You can go to some Shop for repair electrical motor.
sincerely.
E.CUADRA
My 2 years old Reebok one gt40s keeps on suddenly stopping after only few minutes walking on. Could anyone help me what to do?
There could be a few possible reasons why your Reebok One GT40s treadmill is stopping suddenly after only a few minutes of use. Here are a few things you can try:
  1. Check the power cord and outlet. Make sure that the power cord is securely plugged into the treadmill and the outlet, and that the outlet is functioning properly.
  2. Check the treadmill's safety key. The safety key is a small device that helps to prevent accidents by shutting off the treadmill if it becomes disconnected from the control panel. Make sure that the safety key is properly inserted into the treadmill and the control panel, and that it is not damaged or loose.
  3. Check the belt and deck. If the belt is slipping or the deck is not properly lubricated, it can cause the treadmill to stop suddenly. Make sure that the belt is properly aligned and tightened, and that the deck is adequately lubricated according to the manufacturer's recommendations.
  4. Check for any visible damage or loose parts. If you notice any visible damage to the treadmill or any parts that are loose or not functioning properly, it may be necessary to have the treadmill serviced by a professional.
I hope this information is helpful. If the problem persists after trying these steps, it is recommended to have the treadmill serviced by a professional to ensure that it is functioning safely and correctly.
My reebok irun treadmill suddenly stops with E3 error code displayed can you help me please.
Try lubricating the belt. My treadmill requires lubricant every now and then. Its not your treadmill but a treadmill is a treadmill. That's what stops the belt from slowing down due to friction. Go to your nearest Gym they may be able to sell you a tube of lubricant. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Reebok z8 error E03
I can not adjust my tension on my machine
1helpful
Need a manual for a reebok edge series 2.5 treadmill.
go please to www.fitness.manualsonline.com or www.iconservice.com
God bless you
Will a reebok rodger black motor drive belt fit a reebok 2.2edge treadmill
Dear Sir:
Most of the time, can be fit in reebok 22.edge treadmill.Otherwise you can adjust the main motor and puller for to fit.
sincerely. God bless youm
ernesto cuadra
managua, nicaragua. c.a
Reebok 5500C - when turn on treadmill and increase the speed, the motor has a sudden surge, for approx 1-2 seconds, then stops.
hi,
Replase the IGBT on the aluminium heat sink. this problem will be solved. Adde the photo of IGBT .
ajin_g_5.jpg ok
1helpful
2answers
We purchased a reebok edge 2.2 treadmill about 3 weeks ago, a couple of nights ago the electic trip out whilst using the treadmill and since then the belt hasn't moved the display still works and counts...
i had the same problem, i beleive its the motor it may have burnt out.
only had it less than 4 weeks, argos sent a replacement treadmill and took the broken one away.
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
