Question about Sunfire True Sub MK II Subwoofer
Sunfire Subwoofer 110 Noise on input plugin
I've had my sunfire for about 10 years (I know) but it worked great up until a few weeks ago. I got a new tv and took everything down and setup again. Once I plugged in the sub I get an extremely loud noise like when you plug a sub directly to a 110 outlet for power. I unplugged it quickly and assumed I had some sort of connection loop issue elsewhere.
After hours of narrowing everything down to only the sub and the receiver it was still happening. I tried another receiver and a small stereo with a sub rca output and it did the same exact thing but the small stereo produced a much lower hum sound (still way louder than normal "subwoofer hum").
I'm assuming there's something internally wrong now. I did have a power wire come loose inside a couple of years ago but I soldered it back on without any issues. Does anybody know what would cause this to happen? Can I replace something on the board or do I finally have to break down and buy a new sub?
PS. It's not a ground loop issue...
Thanks!
    New Friend:
This problem can also be caused by bad caps. This seems to be a real problem with this unit but considering the age I would replace the caps.
Posted on Dec 16, 2009
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Posted on Nov 02, 2008
6ya staff
SOURCE:
Own a Sunfire True Sub MKII, light on but no bass, when volume on all the way it barely hits. Fuses appear to be ok.Circuit board looked ok I dint notice any blown caps or miscolored resistors. Help?
Start with the volume way down on the sub.
Connect the line out of a source you know is working with cables you know work to the inputs of the sub. Try left and right.
This will let you know if the problem is in the sub or the output you're trying to use.
Oct 05, 2015 | Sunfire True Sub MK II Subwoofer
Hey, I hope someone could help me out! I got a sunfire EQ 12 true signature subwoofer. It worked great at beginning. However, the issue is auto off. It will turn off after a few minutes no matter for...
Auto-off will be a software issue, so no, you can't turn it off. Send it back as a warranty repair. They have a 1, 3, or 5 year warranty. Look at the the support page. Also shows factory repair.
SUNFIRE True Subwoofer EQ 12 Signature TS EQ12
Jul 29, 2017 | Audio Players & Recorders
My subwoofer output is not working properly. I have a sunfire signature that worked all the time. Now the power on the Sunfire will not come. Research says no signal from receiver. I swithed the...
You can prove the sub pre-output works by running an RCA cable from it to the input of a tape deck, TV or any other device that accepts Line In and will either display it or play it. Test it on VERY LOW volume at the receiving device.
Different sub pre-out cable?
Feb 11, 2011 | Denon AVR-4800 Receiver
Active driver Has a torn rubber surround. I was surprised that sunfire neither services or provides parts for this $2500 subwoofer. Truly unbelievable. I've searched high and low for a solution. Does...
phone an electronics parts provider in your area and ask who re -cones speakers.There are usually a few that do that in all major areas.A shop like that will be able to repair it by putting a new surround on it.
Dec 30, 2010 | Sunfire True Sub Signature Subwoofer
1999 Sunfire 2.2L wont start
Try starting it with the shifter in neutral. You might have a bad
Neutral safety switch.
May 14, 2010 | 1999 Pontiac Sunfire
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
My sunfire subwoofer starts making humm noise after a couple minutes while listening music,,, I have to disconnect and connect back, is something that involves equipmenrt adjustment?....thanks
Try plugging the unit into a clean power supply without anything else on it. I had this problem for years and eventually resolved it by moving the system to a different room that has three power circuits - the sub is now on it's own circuit and I don't have the problem anymore.
Nov 12, 2009 | Sunfire True Sub MK II Subwoofer
Sunfire annoying popping noises
If you remove the volume knob, and tighten the nut below, it should take care of the popping noise, as well as any input noise issues. Based on my experiences with my MKII
Apr 01, 2009 | Sunfire True Sub MK II Subwoofer
Sunfire True Sub MK II Subwoofer Logo
1,297 people viewed this question
Top Sunfire Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
