DISH Solo DVR VIP612 Remote Code Scan
Would
you like to autoscan program the Universal Remote that came with your
Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To
auto-program device codes into your Dish Solo DVR VIP 612 Universal
Remote by searching for the code, follow these steps
- Turn the device you would like to control on.
- Press and hold the mode (TV, VCR, or AUX) button until all the other
buttons light up, and then let go. The mode button will flash.
- FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner.
Then press the STAR (*) button.
- Press POWER to
put your remote into scan mode.
- Press the UP or
DOWN ARROW repeatedly until
your device turns off. Each arrow press tries the next code your remote
knows for your selected device type. When your device turns off, you
have found a compatible code. When the remote runs out of codes to try,
the device will flash rapidly eight times.
- Press POUND (#). The mode button will flash three
times as it stores the found code.
- Turn the device back on and try some of the other
buttons to make sure they work. If all functions work, your remote has
been successfully programmed.
- If the code didn't work, repeat this scanning procedure
to find a more compatible code. When your device turns off during your
next scan, press the arrow key again until the device turns back on to
signify you have found the next compatible code.
Your
device's remote control codes for your TV, VCR, or receiver are now
programmed into your DISH Solo DVR ViP 612 remote control.
(The
other way to program your DISH Solo DVR ViP 612 remote control is to
look at the tables in back of the
user manual, and
enter the code directly.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference
DownloadDISH Solo DVR VIP612 Remote Code ScanDISH Solo DVR VIP612 Program TV VCR
Remote CodesDISH Solo DVR VIP612 Program AUX
(Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier ControlDISH Solo DVR VIP612 What Is Limited
ModeDISH Solo DVR VIP612 Change Limited Mode
Looking for code for Jasco 24911, receiver is VIP722K DVR. Thanks!
