Question about Panasonic Cameras
Panasonic lumex camera focus error message - Panasonic Cameras
2 Suggested Answers
6ya staff
SOURCE:
Obertelli
Obertelli
  • 3006 Answers
SOURCE: When I turn the camera
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Panasonic service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 24, 2010
What SD Cards will work with Lumex DMC-FZ7 ?
It will work with any SD card, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Apr 30, 2014 | Panasonic Lumix DMC-FX01 Digital Camera
My Panasonic TZ25 says "System Error - Focus". What should I do?
Panasonic DMC TZ25 compact camera - System Error (Focus)
- Try holding the shutter button while switching on the camera (suggested by Andrea Lock, above). I actually had to try this several times as camera was refusing to reset properly, but after a few goes, lens retracted and camera began to work again. Thanks Andrea.
Feb 21, 2013 | Panasonic Lumix DMC-TZ25 Digital Camera...
Where can I download a user manual for my old Panasonic DMC FX9
You may download a copy of the manual from the Panasonic support site here.
Jun 04, 2012 | Panasonic Cameras
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Lumix FS-15 "System error (focus)"
I have the same issue with my 3 month old Lumix DMC FS15 plus it won't focus and gives the error message to "turn camera off and then on" This doesn't fix it.
Bottom line fix: Don't buy this camera again and don't recommend other buy it.
Sep 19, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Cameras Logo
27 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
