SOURCE: DVD recording freezes up
Freezing like this is usually a sign of lack of memory.
Ensure all other programs are shut down.
Burn fewer files at a time
SOURCE: Easy CD & DVD Burning and Windows Vista
You may need to run the setup directly from the CD rather than letting the autorun start and running it from there. Open up "My Computer" and go to the CD drive, right click on it and select "Explore" find the "Setup" file, and right click on that, select "Run as Adminstrator".
SOURCE: I cannot install Roxio Easy
This is one feature of Vista 64 that most users are annoyed about. It is a security feature that will not allow unsigned drivers to load. Mostly this happens to audio
You need to disable this feature.
Let me know if this works for you.
All the best!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: I'm trying to start Roxio
Please refer to the link below as it will help you resolving this issue, Make sure to follow the steps carefully.
http://kb.roxio.com/search.aspx?URL=/content/000244CR&PARAMS=set-locale=en
Cheers . . .
