SOURCE: olympus stylus 790 sw:windows vista does not recognise the devise?
there is none, olympus shld bl00dy fix the problem
SOURCE: cannot print pictures with dates
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
SOURCE: Need manual for Olympus Stylus 850 sw camera
you can download the manual here http://safemanuals.com/user-guide-instructions-owner-manual/OLYMPUS/STYLUS%20850%20SW-_F Please note that the user guide is in French
SOURCE: why does my stylus 1050 SW says write-protect?
Is the slide switch on the side of the card in the locked position?
SOURCE: Dropped my Olympus Stylus 1050 SW... now it wont turn on!
Get a new camera something broke on the inside of this one the term shock proof does not cover dropping the camera and the term waterproof does not cover submersion in water these terms must be taken very lightly shockproof means a good shaking won't bother the camera and waterproof means a drop or two of rain wont bother the camera. GOOD LUCK
