Main board not on power,dont suspect the power board//
10 blinks IS a bad pwr supply also this model has had problems with the D board
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
