SOURCE: removing handlebar on stihl ms 270 chainsaw
you have to take the top cover off of the engine and then remove the tab that holds the bushing in place alongside the engine. if you just start prying on the plastic plug from the outside of the handle you will damage the retainer. that holds it in place. If you have already done this, there is a solution.
SOURCE: unable to crank Stihl 034 chainsaw because pull cord jams.
i had the same thing with a stihl hedgecutter its a part in the centrefruge that locks if you pull to hard pull slow and let all the cord come out let it in half way full choke on start just where it used to lock and it will start . the bad news .it wont last for long before you smash the wheel thats plastic and if its over about 5 years old they dont have a replacement part hope this helped
SOURCE: need to strip down a Stihl MS 180 C chainsaw to
Chain cover removal for all model 180s is illustrated under "Mounting the Bar and Chain"
Stihl Product Instruction Manuals
http://www.stihlusa.com/stihl_ownersmanuals/MS170_180_Manual.pdf
It has an inboard clutch, this may help.
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care. HTH
Lou
SOURCE: where is the idler screw on a stihl ms 170
This is a link to your OM.
See page 43, that is the throttle adjustment.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
