SOURCE: fault 52
Code 52 is a loss of water during recirculation cycle. Possibly due to a faulty divertor valve. Check to see if water is circulating back into bowl & no water escaping out of the drain hose. May also be caused by a faulty motor controller.
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: fisher & paykel intuitive Fault code 136
Sounds like a motor problem Check the motor harness,connectors and motor for discontinuity.This can be done by taking a resistance measurement between phases of the motor harness at the motor control mudule end.should be approx 32 ohms.You can also check at the motor,I have seen a few open circuit connections where the motor connections (spade clips) Push into the plastic motor housing,Hope this helps.
SOURCE: Our Fisher & Paykel Washing Machine is not
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
SOURCE: fisher and paykel double drawer dishwasher flashes
Hi
Thanks for using FixYa. F1
error means that the flood switch has been activated. You’ll need to reset it by powering off the
breaker or by unplugging the unit from the power socket and mains for more than
five minutes. Please check that there is no blockage in the drain hose and it
is not raised higher otherwise the water will run back to the dishwasher. Also
perform the following procedure---
Please do rate the solution if the issue is resolved or
else post a comment for further assistance.
Thanks
Rylee
