Help me l 1502 hp monitor cable wiring
SOURCE: VGA Cable Wire Colors
I don't think and RGB cable will work with a VGA cable because the signal in the video card is completely different. It's not just the picture but the scaning and refresh rates are totally different. Even if you could wire one it probably won't produce a picture.
SOURCE: Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
SOURCE: Hi there,
I assume the cable is integrated into the monitor so it cannot be changed. VGA is pretty much standard regardless of who makes it. Here is a link to a diagram showing the vga pin outs. you should be able to match this and then repair it. http://www.theavguide.co.uk/view_page.php?page=18
SOURCE: The Envision H170L Monitor VGA cable.
the Envision H170L Monitor uses an interface 1.0x VGA - 15 pin HD D-Sub (HD-15). The same VGA cable wildly use in different computer brands..I was wondering why you have not found a replace for that cable. It can be purchase from any computer store.
If you are planning on cutting the wires and solder it together that would be easy if you have the diagrams of the pin numbering for male VGA connector and the female VGA connector. Check first this diagrams and follow strictly the coding of the wire so that it would be successful when connecting it together.
It is also better if after you solder the wire, you will use an shrinkable tube on the connection. Cover the whole sections of interconnected wires with shrinkable tube before you use the vga cable.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
