Televison & Video Logo
stephen mckee Posted on Nov 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sound disappears
The sound disappears then comes back but the background sound doesn,t when searching for channels
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
  • Posted on Nov 11, 2011
Master
Level 3:
Answers
6993
Questions
Helped
1700105
Points
1261
there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered.
First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV."
Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so."
If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again.
To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.
Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me.
Regards.
How do you get back ota TV Channels now missing on a Sceptre TV?
Probably needs updating. Switch it off and on again then run a channel search within the menu system.
Program local channels
just search automatically the local channels(scan)on your search mode.click asia pacific region or just asia on your menu.but don`t forget to set it to auto system and the sound for ntsc3.58 system so that you can get clear sound.or your antenna doesn`t install correctly?please check it first
I am using this with Cubase AI 4 and my output is too low and if i try and turn it up, i get too much background noise. What am I doing wrong? Also when i listen while recording it sounds low but find, but...
if you have leopard or snow leopard, it is probably osx. i know for a fact that leopard has issues with usb recording devices, i dont know about snow leopard, tho.
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
1helpful
Disappearing screen picture
Sounds like the battery is weak and it tried to save power by dimming the screen. You might need to contact the manufacturer and get it replaced if under warranty. If not, mess around with it a bit and if you can't solve it then buy a new one from the company.
1helpful
2answers
Sound on DVDs
It sounds like she has the player set to output 5.1 surround sound, but only has left and right channel speakers hooked up. Either change the dvd player to only send two channels or hook up a center channel speaker.
2answers
Intermitten issue of no sound while playing NSF: MW
Uninstalled and reinstalled the game.
Everything worked fine after that.
Cheers!
2answers
Video channel disappeared
i just got mine to work i had the same problem, i bought a universal remote, make sure your dvd player or whatever his hooked in, and hit the input button on the remote, it worked for me. I couldnt get anywhere by looking through menu, but i just hit the input button and it magically appeard :)
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
