Question edited for clarity.
It is cutting On and Off due to a device called a Clixon, which is an overheat cut out.
Remove the grille at the bottom below the door and you will see the condenser fins. They will be clogged with lint, dirt and dust. Vacuum it all off. You should be able to see through it. Engineers use a degreasing aerosol spray like this
Web 19 oz. Condenser Coil Cleaner WCOIL19
Home Depot
https://www.homedepot.com > Web-19-oz-Condenser...
Helps remove soil and build-up on condenser coils · Spray directly on condensate coils and wash off detergent with water hose · Biodegradable formula · Aerosol can ...
Rating: 4.2 · 854 reviews · US$8.98
... and then they use a small pump sprayer to carefully flush the dirt out onto paper towels below it. WITHOUT spraying any electrics!
Then go to the back of the fridge (which is normally open at the bottom) and clean the condenser fan motor and blades with a small paint brush and vacuum the dust away. Now make sure that fan is turning when you switch it back on. This fan not only pulls cold air from the front and through the condenser, but it also cools the compressor as well. Overheating a compressor will make it fail prematurely in months.
This should fix it. In a commercial setting, this needs doing every 6 months.
This is your controller manual and details, but that isn't the issue, it is lack of airflow causing overheating.
https://www.google.com/search?q=coca-cola+cooler+with+a+elstat+100+controller
And how to clean the coils
https://www.google.com/search?q=commercial+display+fridge+condenser+cleaning
well it is blowing hot air on the inside
The fridge stop cooling 1 day ago. I cleaned the panel and still not working.
Is there anything I can do to fix it?
