CANNOT RESET E2 ERROR CODE TRYED UNPLUGGING DID NOT WORK
RECEIVED E2 ERROR CODE NOW CANNOT MOVE CONTROLS, TRYED TO RESET BY UNPLUGGING AND THEN HOLDING START BUTTON FOR 5 SECONDS, WAS TOLD BY ANOTHER MAYTAG CANADA REP TO DO THIS.
The F3E2 Error Code indicates that there may be an issue with the Temperature Control sensor. Try resetting the washer/dryer by unplugging it from the outlet for at least 1 minute, and then plugging it back in. Another issue is a blockage in the outlet drain pipe or pump.
The E2 error code on a Duraflame heater usually indicates a problem with the temperature sensor or the control board. Here are some steps to troubleshoot and fix the E2 error code:
Turn off the heater: Turn off the heater and unplug it from the power source.
Check the temperature sensor: Locate the temperature sensor on the heater and check that it is connected properly and not damaged. If the sensor appears to be damaged, it may need to be replaced.
Check the wiring: Inspect the wiring connected to the temperature sensor and make sure there are no signs of damage or fraying. If the wiring is damaged, it may need to be repaired or replaced.
Reset the heater: If the temperature sensor and wiring appear to be in good condition, try resetting the heater. This can be done by unplugging the heater and waiting for 10-15 minutes before plugging it back in.
Replace the control board: If the above steps do not fix the problem, the issue may be with the control board. In this case, the control board may need to be replaced. However, replacing the control board can be complex and is best left to a qualified technician.
It is important to follow any safety instructions provided by the manufacturer and to avoid attempting any repairs if you are not comfortable with electrical troubleshooting.
The E2 error code on an LG washing machine usually indicates a problem with the water supply. Here are some steps you can try to resolve the issue:
Check the water supply: Make sure that the water supply to the washing machine is turned on and the water pressure is adequate. If there is a problem with the water supply, fix it and try running the machine again.
Check the water inlet valve: The water inlet valve is responsible for controlling the water flow into the washing machine. If the valve is faulty, it can cause the E2 error code. To check the valve, unplug the machine and turn off the water supply. Remove the hoses from the valve and check if there is any debris or damage. If the valve is damaged, it will need to be replaced.
Check the water level sensor: The water level sensor is responsible for detecting the water level in the washing machine. If it is faulty, it can cause the E2 error code. To check the sensor, unplug the machine and locate the water level sensor. Check for any damage or debris and clean it. If the sensor is damaged, it will need to be replaced.
If the above steps do not resolve the issue, you may need to contact a professional for further assistance.
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
E1 is humidity sensor error unplug unit and then plug it back in.
E2 is Temperature sensor error unplug unit and then plug it back in this will clear codes. if codes come back on then you will need to replace sensors.
Unfortunately the control board is dead and will need to be replaced. Here is the board to order if you decide to order it. The E2 error code was for a stuck button and it would require the control board to be replaced also.
Here is what the manufacture says about it, my comments are below.
F1 E2 - UL A/D error(s)
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last error code is displayed. 2. Disconnect power longer than 30 seconds. 3. Re-apply power and observe for longer than 1 minute. 4. If failure remains, disconnect power, replace control.
Phil's comments----->
F1 Codes are related to the control itself, if there was a storm, power outage, surge etc it could have damaged the control. Try resetting the board by unplugging the range or turning off the breaker for a couple minutes. Restart and see if that helps. If not you will need to replace the control.
The part number for this unit is 4453614 and runs just over $300.00
Errror code E2 indicates a paper-out situation. Fill the paper. If it's full, fill the paper out and reinsert it. If that doesn't work, try this...
1. Power off the printer 2. Unplug the printer's power cord, wait 5 seconds then replug the power cord in. 3. Hold the Power button for 6 Beeps 4. Release the Power Button This will reset the printer and should resolve incorrect detection problems
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
