So i bought a panasonic dvc30 off of ebay but when i bought the battery and charger for the camera i tried to charge the battery with a wall charer and the batter said to charger for 12 but the the charger said it was green at 3 hours so whats going on because when i tried the battery the camera wouldnt start??? please help
SOURCE: Battery Wont charge
I have the DMC-TZ1. The charger is labelled "Panasonic DE-A25 battery charger". It has 3 contacts where the battery fits in. With no battery in place, the voltage between the top and middle pins is 2.61 V. The voltage between the middle and bottom pins is 2.19 V. Check those voltages. If they are very different from mine, I rather think the charger is not working. You can buy the batteries for very low prices on ebay from Hong Kong and other asian sources, but I've been told by someone who tried them that they do not work. Perhaps you have run into one of those. If you can find someone else with the same battery, a quick swap will tell you if your camera is okay. I got my camera on ebay and it works perfectly.
SOURCE: Won't start
how old is the battery? if it's more than 2 or 3 years old, it may not hold a charge. swap a known good battery and see if it works.
SOURCE: hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
SOURCE: panasonic ds27 camcorder charge
It could need a new battery. The battery can't hold a charge in it anymore.
SOURCE: i bought a used panasonic TH-50PZ85U plasma TV
My ex-husband threw away the pedestal stand for the Polaroid Polaroid FXM-3211C TV DVD Combo which I now have. I need a pedestal stand....do you know where I can find one?
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
