You dont need camera from the store.
the camera inside (is it there)
works
the support page is here, the camera software is there
under title multimedia
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv6-2100-entertainment-notebook-pc-series/4041735/model/4121235
the software to run there is
Software-Multimedia
Version:
4.2.3303 Rev.
Operating systems:
Windows 7 (64-bit)
Release date:
Dec 3, 2010
File name:
sp51029.exe
(141.7 MB)
why not keep you PC 100% HP and use there support page.?
1st.
no store bought camera stated, name , model, at all
so cant help there, its not HP for sure, right?
Your new camera driver is simply not compatible with the 64 bit version of windows. Get a camera that is specifically designed with a driver for Win 7 64 bit version.
SOURCE: hp laserjet 1000 series no driver update for vista 64-bit
Go here and try this Driver it should clear you right up if not comment back here and i'll get you some more info as I find it :) http://www.opendrivers.com/driver/241620/hp-universal-print-driver-pcl5-4.1-windows-xp-x64-2003-x64-vista-x64-free-download.html
SOURCE: When I plug in the webcam, it says USB DEVICE NOT RECOGNIZED
These camera seem to be delicate. Call Microsoft support number that is on the documentation and they will send you another one. I did this and the replacement VX-3000 works perfectly.
SOURCE: Hp webcam's microphone not transmitting sound.
the cam has to be configured for whatever program you are trying to use.
have you checked device manager to see if driver shows
then click and update driver
SOURCE: acer 5535 laptop crystal eye webcam problem
you have to set cam up with the program
After you start Windows Live Messenger,
expand the view by clicking on the square
on top left next to the red X.
Then on the Windows Live messenger window on the
right side, click on “ “Show Menus.” And then click
on “Show the Menu Bar”.
Next go to the Menu Bar on right side, click on Action.
Go to “TOOLS” and click “Audio and Video Setting
and follow the instructions.
if you still have a problem please let me know and don't forget to rate
SOURCE: XP Windows not recognizing Sony 800x camera
Install the Driver Again
http://www.sony.co.in/support/download/140059/product/dcr-hc28e/modelfirst
Enjoy
rajkumar
software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
It might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you
want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
Hope this helps.
