Hello Richard, welcome to FixYa.
This should address your post...gaining access to the lid switch. The lid switch failure is definitely a common top load washer problem...particularily with the Whirlpool built units like yours. Here`s how you can repair it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-loadwasher, not necessarily applicable to ALL...but it cover's yours)
Here`s a helpful link for changing it out there are a couple of different types,
http://www.youtube.com/user/RepairClinic#p/u/5/MFsvLiuTniU
The lid switch will look like this...double check with your model number at "searspartsdirect.com"
Let me know how you make out. If this is something you think is not within' your scope of expertise please call a pro. I think you'll be fine with the tutorial video'
I will try to help in any manner I can of course as well. Good luck. Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
SOURCE: Replace "lid switch" on kenmore washer 110-20702-991
Go to www.appliancehelponline.com/servicemanual.html this will walk you thru the lid switch replacement.
SOURCE: I have a kenmore washing machine model #
two screws on the back in the cornes of the control panel
roll the panel up and over the back
you will see two brass clips on the very back corners
stick a flat head in the front hole ctch the clip and push back
before you pop the second take a minute to note the orientation then pop the other
disconect the lid switch plug
on the back wall
tan and white wires
now you can pull the entire box off the washer
the lid switch is mounted underneath
SOURCE: how to replace lid switch kenmore 110 22922 washing machine
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the cabinet.
Then see the following for how to release the console and pull the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=9b19162f839199d33f88dac696ac636c
SOURCE: how to get access to the lid switch
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20692000&pathTaken=partSearch
See the diagram (and parts list) for the top and cabinet.
Also see the following for how to release the console and remove the cabinet to gain access to the switch.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=994d701a894fe6b21797914781777f3c
SOURCE: Whirlpool MOdel 110 23832100 Lid Switch is broken, need replacing
The following link explains step-by-step how to access the lid and replace it:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
You do not necessarily have to disassemble the entire washer, but you DO need to release the clips that hold the washer casing to the back panel and frame so you can lift the case up enough to access the lid switch. The switch is mounted to the underside of the washer top panel. With the washer case installed, it can be difficult (if not impossible) to access the switch through the wash tub opening. The process is much easier than it sounds and will offer you the best access. Removing the washer case will also offer the quickest method of installation.
If you have not purchased a replacement switch, yet, you can purchase them from any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. If you do not wish to order on line, this is a common part that any appliance parts retailer should carry as part of their in-store inventory. The part number for the model number you provided is 3949238.
If you have any questions, please post back and let me know. I hope this helps you.
Testimonial: "Gott'er DONE! Thanksfor the great info!"
