Find filler loop which should be near boiler it is connected to the main and connects to flow or return on your boiler and only fill to 1and a half millibars which is a dial on your boiler
find filler loop which should be near boiler it is connected to the main and connects to flow or return on your boiler and only fill to 1and a half millibars which is a dial on your boilerfind filler loop which should be near boiler it is connected to the main and connects to flow or return on your boiler and only fill to 1and a half millibars which is a dial on your boiler
You can't post conmments that contain an email address.
Some combi boilers have a 'Keep Warm' function. Check to see if your combi has this feature. This is a function where the system preheats an amount of hot water to provide instant hot water when you turn on the tap/faucet. To do this the combi will start up when it detects the stored water is below a certain temperature to reheat it ready for use. This can be turned off if you prefer not to use it.
You would have to have a indirect cylinder and motorized valves ,clyinder stat . It could be done you would need a heating company to check it all out .
http://www.bhl.co.uk/uploads/article1477/Baxi%20Duotec%20HE%20Combi%20Boilers%2024,28,33,40%20Installation%20Instructions.pdf top the pressure by the filling loop
The boiler has a filling connection which uses a filling loop to connect the boiler to the mains supply for the initial fill and subsequent fills.
See the link below from the manual you can buy the filling loop connection online or ebay its a simple task to replenish the pressure. Worcester GREENSTAR 25Si Instruction Manual Filling The System
