Lexmark connect time executable has stopped working Problem Event Name: APPCRASH Application Name: LXCRtime.exe Application Version: 1.32.0.0 Application Timestamp: 456336ef Fault Module Name: LXCRuldr.dll Fault Module Version: 1.32.0.0 Fault Module Timestamp: 45633712 Exception Code: c0000005 Exception Offset: 0001c6b9 OS Version: 6.0.6001.2.1.0.768.3 Locale ID: 2057 Additional Information 1: 6b14 Additional Information 2: b50f8128154c53589973815637913693 Additional Information 3: 18b6 Additional Information 4: 426838011f6ec2e4b560cf6a545b9104
SOURCE: aioc.exe has stopped working lexmark 5400
this usually happens when you try using the old cd on a vista os.. most
of the time the cd was made to work on xp only since during the time of
release of those printer, vista was not yet out of the market.. try
downloading this patch
ftp://ftp.lexmark.com/driver/inkjet_drivers/AIOCenter_patch
disable user account control first.. you can do this in msconfig on the tools tab then run the patch
chose
the right series of you printer.. normally when you run the file it
will extract the file and run the patch.. cancel the application after
extracting the file..
go to c drive on you computer... look for the folder LxkPatchAIOC
go inside the folder and look for the word aioreg.. right click on it and choose merge...
that should fix the issue..
if in case it didnt work on you... try calling 1-800-lexmark
you can email me at [email protected] for more questions about lexmark
Are you still able to connect and print to the printer besides having this error display?
