Apple iPad (16 GB) WiFi Tablet PC Logo
Juli Posted on Nov 15, 2011
Can I adjust the volume and equalizer on songs in iTunes library on ipad like I can on my pc?
I was able to individually adjust song by going to "get info" then to "options" to turn up volume and switch to "rock" on the equalizer. Now that I upgraded to iOS5 and iCloud, can I do those things on my ipad?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Nov 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
3061
Points
19
Yes you can, however it is not within iTunes. It is under the settings in the iPod section. Here is a link to someone who has posted instructions with pictures. I hope this helps.
http://www.askdavetaylor.com/get_find_ipod_itunes_equalizer_ipad.html
How do I delete music from my ipad
Method 1. How to Delete Individual Songs from iPad
Step 1. Launch the Music app on your iPad.
Step 2. Tap "Songs" on the bottom to see all of the music on the device. Choose the individual track you want to delete and slide your finger to the left across the songs.
Step 3. Tap on the red "Delete" button to remove music from your iPad.
Get another two ways in this guide: https://www.imobie.com/support/delete-music-from-ipad.htm
tip
How to Remove Songs from iPad in 3 Ways
Part 1. Delete Individual Songs from iPad
Part 2. Delete All Songs from iPad
Step 1. Go to the iPad's homepage and tap on "Settings" icon.
Step 2. Tap "General" > Select "Usage" > Choose "Music." The iPad will display how much space is taken up by music on your device.
Step 3. Tap "Edit" button on the top-right > Tap the red icon next to All Music > Tap on "Delete" to remove all songs from iPad.
Part 3. Delete Selected Songs from iPad with AnyTrans
AnyTrans is an all-around iOS files manager that made to transfer and manage all your iPhone, iPad, and iPod content, such as, music, videos, photos, contacts, notes, messages, apps, etc. You can freely add or delete songs from your iPad with AnyTrans.
Step 1. Download and install AnyTrans on your computer. Run it, and connect your iPad to computer.
Step 2. On the homepage of AnyTrans > Click "Audio" > Select "Music".
Step 3. Highlight the songs you want to delete and click the trash icon on the top-right of this window to delete the unwanted songs.
Resource from: How to Delete Music from iPad
How to Delete Music from iPad in Three Ways
1helpful
4answers
Transfer photos from my PC to my ipad mini. I have tried iTunes but I don't understand it
Try downloading an app called Shareit.
When attached to the same WiFi, you can transfer Photos directly from iPad to iPad and even between Windows and Andriod devices. You start Shareit on both devices and send from one and receive on the other.
2answers
Sync iphone and ipad
Hey friend. What kind of files do you want to sync between iPhone and iPad? Let's say, if you're planning to sync music from iPhone to iPad, you can simply rely on iTunes.
Please note that if you have hundreds of thousands of songs in iTunes Music Library, you'd better create a separate playlist for the songs you want to transfer. Then you can choose the playlist when you sync music to iPad with iTunes. The following guidance will show you how to transfer songs from iPhone to iPad with iTunes.
1. Transfer Purchased songs from iPhone to iTunes Music Library.
Sync Music
2. Connect iPad to computer with USB cable.
3. Click the iPad icon and choose Music.
4. Check Sync Music, and choose the iPhone music playlist.
5. Click Sync at the right bottom.
3 Ways to Transfer Music from iPhone to iPad
How to delete songs from itunes
I think you need to remove them from the computer that you are syncing to (and be sure that the sync is set up so that your device syncs to the master list on the computer).
Can't sign on or register
Connect ipad to compuer. Oped itunes. Drag the songs from computer to itunes to add to ipad
How to delete from ipad 2
You can delete songs from iPad with iTunes with ease. In addition, Leawo iTransfer is another easy to use solution. And it can delete iPad songs in batch. Just follow below steps.
Step 1. Run Leawo iTransfer and connect iPhone to computer with USB cable. Step 2.Click the name of iPhone and choose Music library in the left sidebar. The music files will display in the right part.
Step 3.Check the songs you want to delete, and click Delete button in the top middle. Then click Yes in the pop-up dialog.
After that, Leawo iTransfer will start removing music from iPhone, and you'll get rid of the songs when the deletion finishes. With Leawo iTransfer, you are able to manage other kinds of files for iOS devices as well. For example, you can backup iPhone photos to computer with this software.
choose-iphone-music-library-2ka233npl0212ndjbhnpio3z-1-0.jpg For more methods, check: How to Delete Songs from iPhone
4helpful
5answers
Adding music to iPad
You can add music to the iPad by directly downloading from the iTunes app or by importing your music into iTunes on a computer. Once your music is imported/downloaded into iTunes on a computer, you then just need to sync the music by connecting your iPad to a computer.
Itunes syncing problems
I met some similar problem too with itunes. But did you try other third party software to transfer your songs or photos? Maybe you can have a try. If so, look this:
3 Ways to Transfer Music from iPod to iTunes Library If the problem still exists, you may have to reinstall your computer OS.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
