The F12 error does not appear on all washers. On a Hotpoint (you didn't state which washer you had), F12 indicates "No mixed fill - Check water supply". Check water at the taps as well as the hoses to ensure a constant water supply.
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
error code 12 is "communications error" Ford manual says replace radio. You may remove the radio open it and check for bulging capacitors, go directly to manufacturer webpage for a replacement capacitor.
U2
04
EEPROM serial communication error
11
counter check sum error
12
adjustment value check sum error(EEPROM)
40
CRUM communication error
U2
04
EPROM error
11
Main counter error
12
EPROM error
U2
04
11
12
40
CRUM communication errorYou need the service help. It is no a distans work Good luck)
ERROR-11, 12, 17, 30 Dirty disc Clean disc.
ERROR-11, 12, 17, 30 Scratched disc Replace disc.
ERROR-10, 11, 12, 15, 17,
30, A0
Electrical or mechanical Turn the ignition ON and OFF, or switch
to a different source, then back to the CD
iiMesisage Cause Action
30, A0
i hope this answers and solves your problems.
30, A0
